February 2, 200521 yr I have been looking and studying my pcv(positive crankcase ventilation) system and was wondering what would happen if I was to remove the valve covers, install extra fittings for mounting either vacuum lines or breathers, and using the existing(factory) fittings for connecting to the pcv valve( via vacuum hoses and a tee to combine the two and go to the pcv valve). I was thinking about this design so that everything would be a little more straight forward and for the simple fact thatit would be like conventional PCV systems. Does anyone see any potential problems with this design? Thanks in advance. Patrick
