flatrock Posted February 12, 2005 Share Posted February 12, 2005 Hi, short version: If I (re)program my Alpine system remote on my '02 OB at least 4 times it should not work with any other cars. Right? long version: We have two Outbacks, a '99 and an '02. I programmed two Alpine system keyless entries to work with both cars, so my wife and I would each have access to each car. We had a QS remote starter installed in the '99, they said they couldn't get around the alarm so we had to buy their transmitter that locks/ unlocks the doors and starts the car remotely. We bought 2, one for each of us. It gets confusing with two transmitters on your key chain, we're always setting the alarm off by locking it with one and unlocking it with the other. I thought it would be easy enough to delete the '99 codes from our original Alpine system transmitters by, following the manual instructions, reprogramming the '02 at least 4 times. Shouldn't that make the '99 not work any longer with the original Alpine system transmitters? As you've guessed by now, it does not. Ideas? Thanks in advance, Mark Link to comment Share on other sites More sharing options...
later, Peter Posted February 12, 2005 Share Posted February 12, 2005 this may not be helpful at all... I have found that the key to this mess is the secret code on the back of the keyless remote... that is the FCC number (as I recall)... if these are different then they shouldn't work the alternate vehicle's system... however, the same numbers will allow you to work each other's systems.. I do recall a notation in the reprogramming for the '99 that states: all the disconnest turn key stuff then ...."repeat the door open/close remote set for up to 4 remotes. If less than 4 remotes program all FOUR channels with your existing remotes." Help or not there it is.. Later, Peter Link to comment Share on other sites More sharing options...
