February 13, 200521 yr hello this is my first post on these boards here so i will try to make a good impression.....I am goin to look at a 1993 legacy turbo(awd unknown as of right now) on friday.. i would like to know the things that were common problems with these cars and if i should look at anything in particular when i do go to test drive it... this car is a located three hours from my house so i want to make the trip worth while.....is there a way to tell if the turbo is weak/ in need or replacement?....does this car require premium fuel?...and of course where can i get replacement parts......im assuming that last question has been asked/answered before so i will search the boards for it too......thanks so much -Shawn
February 14, 200521 yr If you did pick up the car, you may want to check out www.bbs.legacycentral.org there's a lot of good info about the turbo legacies.
