now the clutch won't ENGAGE, flywheel step?
ok, thanks to Tom, I got a clutch disc and pressure plate and TO bearing, got a new pilot bearing from my father, and got a flywheel from Miles. The tranny is back in, but now the clutch won't engage. There is a ridiculous amount of slop in the clutch fork , nearly the full travel of the lever. If you look in the opening for the clutch fork you can see that the TO bearing is in the right way, but its not touching the "fingers" on the pressure plate until its at the full extent of its travel.... WHAT did I do??? are all ea82 flywheels the same? or are some of them thicker or deeper?
