March 18, 200521 yr Hello every one I bought another subaru this week (needed a better car). It is a wrecked car but not to sevear. was hit in the back on passenger side. but the thing that is bothering me is that the rear windows will not roll up (power windows). thats with using the switches in the rear doors and the switchs in the drivers door. the windows will go down. could this just be a blown fuse? (id go look but its dark and the temp is about 5f out side) thanks for any help
March 18, 200521 yr Motors could be burned out/burning out. Try pulling up on the glass while you hit the switch. The motors in my Loyale were getting slow like that- they would rocket down, but took forever to roll back up.
March 19, 200521 yr Author ok i was able to look at them tonight and found that the motors are working great. it seem that the 5pin connector in the doors may be coroded after i put the doors semi back together i tried the switches and they worked for a few times then stoped again :/ so ill just lock the windows until i can get them properly fixed thanks though
