critical_max Posted March 27, 2005 Share Posted March 27, 2005 I did it the quick way, running 2 front stock speakers from a $12 Goodwill-sourced Sony head unit. Metra brand dash+wiring adapters from The Stereo Shop on 7th and Washington. Took about 15 minutes to install, with the excellent directions on this site (search for "ea82 stereo"). So I finally have tunes in-dash! This is a good thing, cause I burnt out an alternator running an inverter to a boombox a while back. Still need a DIN "frame", not sure what you call it, the thing with the metal tabs that surrounds the head unit and holds it in place on the adapter plate. Right now the unit has a wicked lean on. Also, need to take the time to get the rear speakers hooked up - I think there's more than enough info on this site to do the job easily. Also came with the kit: Justy and EA81 adapter plates that I'm not using - if anyone wants them just let me know. I guess I could mail them out if you're not in my area. No guarantees that you'll have everything to install a stereo, but it should be all the adapter plates at least. Link to comment Share on other sites More sharing options...
