April 9, 200521 yr Hi, The condenser fan next to my cooling fan on my 91 Legacy Turbo does not turn on when I turn on the AC. In fact, I have never seen it running at all. My AC was converted to R134a about three years ago and works okay, as long as it doesn't get too hot out (30+ degrees C). If I'm in city traffic in the summer heat the compressor starts cycling off and the AC can't stay cool until I get moving again. So I'd like to get the fan working before summer comes again. Any ideas of what could be wrong? The fuse is okay, I haven't been able to trace the rest of the wiring. Thanks, Ian
April 10, 200521 yr I would start with the relay as that is easy to test. If that works next check for power at the fan. Someone with schematics (Josh) for your car may be able to give more precise instructions.
April 10, 200521 yr Yeah, start with the relay....check out this thread for wiring info. The 92 should be the same as the 91 for wiring. http://www.ultimatesubaru.org/forum/showthread.php?t=34140 More then likely, you need to add refridgerant.....that's the reason it's not staying cool.
