April 16, 200521 yr I'm looking at buying a 92 Loyale from a auction. The vehicle was towed to the tow yard. I don't think they towed it with a flatbed trailer. I assume it was towed with only the back wheels on the ground. If it was towed that way does it damage the vehicle? THe dealer said you need to get all wheels off the ground to tow it.
April 16, 200521 yr as long as the car was not left in 4wd it would be ok, as the rear wheels and driveshaft would spin freely and is not engaged with the tranny in front wheel drive towing on all 4 is ok for a few miles, but the pump in the tranny wont be circulating the atf but in fwd mode if the front was on the tow truck and the back wheels on the ground this is ok
April 16, 200521 yr Author I hate to sound really stupid, but how to you shift the vehicle from 2WD to 4WD. For some reason I thought the wagon was full time 4WD. Thanks as long as the car was not left in 4wd it would be ok, as the rear wheels and driveshaft would spin freely and is not engaged with the tranny in front wheel drive towing on all 4 is ok for a few miles, but the pump in the tranny wont be circulating the atf but in fwd mode if the front was on the tow truck and the back wheels on the ground this is ok
