catboat Posted July 8, 2005 Share Posted July 8, 2005 I have a '99 Forester, automatic transmission, 4 cylinder, with 60,000 miles on it. While in "drive," and coming to a complete stop (ie stop sign, light), I will sometimes experience transmission slip. I press the accelerator down, and the engine revs-then the transmission engages. It doesn't happen all the time. It doesn't seem to matter if the car if hot or cold. Fluid level is good-perhaps just a little high (when hot, and engine running). Had the same problem last summer. Took it to a Subaru dealer, and they did a tranny flush. I asked if they changed the tranny filter, and they said it doesn't have one. (Is this correct? Seems odd). That was at 50,000 miles. It seemed to solve the problem, up to a couple of weeks ago. I bought the car used last summer with ~ 47,000 miles on it. It has not been used to tow. Any thoughts on what can be looked at? I don't have any transmission slipping in any other gear, just going from dead stop to first. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted July 8, 2005 Share Posted July 8, 2005 It might be a sticking valve or solenoid. There isn't a filter, just an internal screen. The newer ones got a spin on external filter, however I don't know how effective it is. It's probably just a screen type filter as well. Other then putting some synthetic trans fluid in, not sure what else to suggest. Quote Link to comment Share on other sites More sharing options...
