oil pump loyale 91 4WD station
hi all!!!
i have to make a big service to my suba.
clutch, puting in a power steering, water pump & timing belt.
my quwestien is if you know a url with a guide how to replace oil pump, since i have a volves noise.
also i have to know if it will help this noise, since it has a timing belt
motor is ea 82.
we have a new club 4 israel subies, on http://subaru4x4.net/
waiting 4 replay!
http://www.finleyweb.net/default.asp?id=142
This is the Factory service manual. It has the lubrication part, but it is not complete.
A oil pump reseal may fix the noise. Its probably cause by oil pump sucking air, lifters not getting oil or clogged by bad oil, and there is a bolt/spring in the head that can go bad and cause the tick. You may have to take apart the lifters or run some lifter free up flush through it to fix the problem. You can only try...
