July 11, 200520 yr Hi I had my oil changed at jiffy lube (bad idea!) and as I was driving away my speedometer and odometer stopped. I assume they accidentally shook something loose, does anyone know where I would look to check/fix the problem (please be specific, I am not sure where the speedometer cable/parts are located, possibly near the oil pan?) It is a 1992 subaru loyale. Thanks
July 11, 200520 yr On our 86 and 87 Subaru wagons - both with 4x4 5 speed manual transmissions - the speedometer cable goes into the top of the transmission on the right side. Don't know is JifferLubePerson did anything with your gear lube, or even if you have a similar configuration onyour Loyale, but that cable just pulls out the top as I understand it. Rick
