July 30, 200520 yr was wondering if anyone had a recommendation for a good but cheap window tint place in the seattle area.... thanx!
July 30, 200520 yr solar reflections.... they're in Auburn the owner/operator is a good guy - professional and a scoob owner more info: http://forums.nasioc.com/forums/showthread.php?t=781012&highlight=solar+reflections Jamie
July 30, 200520 yr Author yeah, already got a quote from him, problem is i already have some tint on it so i have to pay for it to be removed and then new stuff put on, and i have found that prices are much more expensive here in seattle then they were in denver
July 30, 200520 yr you could do the prep work yourselfsome times if you warm up the glass fromm the outside it softens the glue.when i pulled the tint off my legacy that was done by a tinting shop,it came off real easy.there's some products you can buy that aids in the removal of tint also.if you do pull the tint yourself you'll need that stuff anyway.walmart carries it,in the auto dept.believe it's called tint-off or something similar.
