September 20, 200322 yr My son has a 1990 Legacy wagon. He says it is making a whining noise when he presses the gas pedal. Could this be the fuel pump? Rick
September 20, 200322 yr The fuel pump would be more likely to make a "whirr" noise. It could be an electrical problem that interferes with the stereo and whines through the speakers. If the alternator diodes have burned out it will produce AC instead of DC and make a whining noise. It will also tend to get abnormally hot.
September 22, 200322 yr if the car is off, ignition in the ON position, and gas pedal pressed, you will hear a noise, it's normal.
September 22, 200322 yr My car makes a whining noise that comes from under teh hood when I press teh gas pedal, especially after the little green light on the dash comes on
