Guest jmr052 Posted July 31, 2003 Share Posted July 31, 2003 Is there only one way to put the center carrier bracket back on? Should it go into the tunnel or outside of the tunnel? Thanks, Jay Quote Link to comment Share on other sites More sharing options...
Guest alpha0001 Posted July 31, 2003 Share Posted July 31, 2003 if you look closely you will notice that one bolt bracket on one side is slightly higher up from the other side of the center bearing and goes up a little more, and if it was put in the opposite, it would fit out of whack.. anyway it should go up inside the tunnel, and make sure you got it facing the right way (so the drive shaft is straight) if you removed it and are now putting it back on the drive shaft pieces. -Mike Quote Link to comment Share on other sites More sharing options...
Guest jmr052 Posted July 31, 2003 Share Posted July 31, 2003 Thanks for the tip. I forgot how it went back so looked at a picture in the Haynes and it looked like the bracket was below the tunnel. All I did was drop the shaft to change the tranny. However, I am getting some vibration noise when maintaining speed over 55 or when going faster and having it in neutral. Also the exhaust didn't seem to fit back the same, rubbing/touching the driveshaft. I will get this fixed before going home. Thanks, Jay Quote Link to comment Share on other sites More sharing options...
