September 24, 200520 yr I am about to drop a 1.8 engine into a 89 DL Wagon. The engine came out of a 89 Loyale. Before I put the engine in, should I do anything to the engine while it's out and everything is easy to get to. How about anything in the engine compartment or the transmission? Are there any parts I should consider changing or any adjustments I need to make? If anyone has any suggestions, please let me know. Is the transmission in the 89 Loyale 4WD interchangable with the transmission in the 89 DL Wagon 2WD? Both transmissions are automatics. Thanks guys, PW
