October 11, 200520 yr Greetings,I have a '93 loyale.I need to change the 'fan' belts.The outside belt is simple,but am not sure about the inside belt.This is my only car at the moment,so I dont want to take it apart with out being able to re assemble it.Is there anything I should know about removing the inside belt?Thanks. BTW-looked at FAQs,but could only find info on timing belts
October 11, 200520 yr Does your Loyale have Air Conditioning? And, if so, is the compressor outboard of the alternator or inboard of it (between alternator and power steering pump)?
