92 Legacy A/T external filter kit photo added
Josh,
Yes, I found your picture amongst "searching" for a topic discussing the routing of the transmission lines. I'm replacing the one on my legacy wagon, and the kit came with a new bracket, new lines, the filter etc.
Had I taken a picture of the connections before disassembling it I wouldn't be here. Had I known it was going to be 2 weeks before finishing the water pump, front crank seal, timing belt etc etc I would have taken a picture! I think how it goes is the:
Bent upwards metal line at bracket to rubber hose on "IN" side of filter, "OUT" side of filter via rubber hose to upper connection of radiator/transmission cooler; lower rubber hose from the body just above the lower radiator hose to the lower connection of the radiator/transmission cooler.
Looking for a confirmation on this. Thanks!
