Headlight wiring colors - help!
Ok, the wires to the headlights (9007 bulb, '98 legacy) is: black/yellow wire is ground, yellow is high beams, red is low?
Is that right?!?
ground one side and touch it to the contact you wish to test with high beam on. If it lights on high beam voila! Then find low beam and the other is ground.
