justy help needed
hello every one. i have a couple questions someone might have experienced in the past. the car is a 88 justy and the dash lights quit working. checked all the fuses and all are good. ????? next i have gas running out the canister on the fender well. any help??? also had to disconnect the chock to get to run at all. hummm. thanks all jd's
  • 4 months later...
First Last: The gas leak: Sounds as if you have a sunken float in the carb ( If carberated) or fuel lines were improperly disconnected.
If carbed, and the cab has not been overhauled, have it done as the float and needle seat will have lived their useful life by this time. There used to be a rebuild kit from Standard Products.
This is doable IF you have experience rebuilding carbs.
Good Luck.
