Back on the road
Some of you may have read my earlier posts about the accident and the water pump problem (wrong size pump). This morning I fabbed a spacer for the pump out of a couple of 5/8 inch washers and cut down some 6mm bolts for studs. The Soob is back on the road and running fine. In addition to the body parts I swapped out, it now has a new water pump, resealed oil pump, new timing belts, new cap and rotor. It's happy now and so am I.
