Spliting block, (Completed) cancel...
Hey,
O.k, ready too split block. Chiltins says: (wrist pins are out, bolts loosened.)
9. Remove the cylinder block connecting bolts, except the one under the center journal: loosen the remaining bolt until it can be turned by hand.
So the last bolt to come off is under the center journal....hmmmm... which bolt might that be.... and is it that important....
From this point is it a putty knife too slice in between and wrestle on floor?
Any tricks or just take bolts out, roll so 1 & 3 cylanders are up and pull?
Noob's.:rolleyes:
Pulled bolts, smacked a couple time with rubber hammer, came right apart.
No problem.... Much ado about nothing.
