December 2, 200520 yr Hello Fellow Soob People My blower motor is making a vibration and sounding bad. How hard is it to locate remove and go through this unit. I've had such wonderful luck rebuilding different things on my soob, and I think this unit needs my help. I beleive it's underneath the pass. side dash since thats where all the ruckus is coming from, and I haven't been able to tear into anything yet, just looking for some advice. Thanks
December 2, 200520 yr I changed out mine for a new one a few months ago. It was easy to get at. I pulled the plastic panel off the is right below the glove box. This exposed the blower motor. IIRC it had 4 10mm bolts holding it place and one of them also held the resistor pack in place. A replacement motor was 35 ish from checkers. -=fred=-
December 2, 200520 yr Author Cool Thank you. I'm gonna work on it tonight. I changed out mine for a new one a few months ago. It was easy to get at. I pulled the plastic panel off the is right below the glove box. This exposed the blower motor. IIRC it had 4 10mm bolts holding it place and one of them also held the resistor pack in place. A replacement motor was 35 ish from checkers. -=fred=-
