December 30, 200520 yr Question? I have recently replaced my worn EJ22 engine(264,000mi) with a junkyard used engine. I have always used the small marks on the rim of the cam pulley to set the timing belt. On this engine I had to use the large arrow that I had thought was the valve lash adjustment mark. Has anyone experienced this oddity? Engine runs great! Go figure! Looking for insight.
December 30, 200520 yr Large arrow on the cam sprockets? Did it not have the markings on the cam sprockets? If not, that's very strange indeed.
December 30, 200520 yr Author Large arrow on the cam sprockets? Did it not have the markings on the cam sprockets? If not, that's very strange indeed. The engine is a '93 EJ22 SOHC 2.2L N/A. There are two marks on the cam pulleys/Sprockets. A small notch on the rim and an arrow on one spoke.
December 30, 200520 yr The markings on the edge of the cam sprocket is what you want to align things too. Here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/
December 30, 200520 yr Author The markings on the edge of the cam sprocket is what you want to align things too. Here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/ Josh: That’s what I have always used. The strange thing about this engine is I had to use the arrows on the pulley to get the thing to fire. It rather blew my mind. The engine with this setting is running fine. Compression checks good also. Timing right, power is good. It’s such a strange oddity I was curious if anyone had seem this before. I can’t figure out how this could have happened! Hey thanks for your website. I have used your instructions on the D-check mode and clearing the ECU. Great job!
