is a 2004 forrester...
Take off the valve cover and turn the engine to TDC on each cylinder. You may want to get a manual to help you but these are fairly easy with a feeler gauge and a set of wrenchs. On some of the earlier engines don't ask.
Thanks, Couldn`t manage to find a manual. Even looked up Haynes, nothing. Do you know where I might find specs on valve clearance?
do you know about endwrench the Subaru tech site? Do a search here for it if you can't find it. I have a Chiltons manual home and if you have not found specs by tonight I'll check that. I don't trust the Chiltons as much as real Subaru info though.
I could not open this with my laptop but if you need more I have my Chilton's now.
