January 11, 200620 yr I'm trying to figur out how to retrieve an ABS code for a 94 Legacy. My manual says and Led is found next to the ABS module underneath passenger front seat that will flash code after driving 19 mph. I find the ABS module but not any Led. Any information would be greatly appreciated. Thanks. Kevin Friedli
January 11, 200620 yr The LED light is on the ABS computer. There is a little flap of carpet you should be able to lift to see the LED light blinking.
January 12, 200620 yr Author I apologize I should have been more clear on original post. After not seeing the led through the flap in the carpet I removed the passenger seat and carpet and completly removed the ABS module and still could not find an led. Also the ABS module has only one large connector plugged into it. My manual shows two different smaller connectors on the 94 model. This is why I thought to look at the 95 model year and the process to pull codes for a 95, which says to short pin "L" at diagnostic connector under left side of dash. I believe I found this connector and the ground wire to short it with but there is no terminal in the position that the manual says to short.
January 12, 200620 yr What manual do you have? I can check my factory manuals when I get home and see if the 94 is some how different....I don't think it is...but I can check.
January 14, 200620 yr It says there should be an LED. It says if the LED doesn't display then there might be an issue with the power supply may be inoperative. Is the ABS warning light on?
