1987 Justy
Hi
The electric choke just stoped working. I checked and there is no voltage at the terminal. I ran a jumper from an ignition source and now it works. Any ideas so I can fix it right?
Thanks
buy a cheap multimeter, and trace the wires back from the choke until you get 12V - is there anything else that stopped working about the same time? did you check the fuses? I do not know Justys well, but this is just a normal T-shooting proceedure
good luck
Hi
Yah I did the volt meter thing and kind of got lost in the cables.
The fuse is good and nothing else stoped working. I was kind of hoping that perhaps there was a temp sensor in the line that I don't know about. I will do a full blown diagnostic this weekend.
