January 21, 200620 yr when im driving in the dark, and i want to switch to the high-beams, every thing goes dark. Relay? If yes, where can i find the relay? Thanks Loyale 92 wagon
January 21, 200620 yr when im driving in the dark, and i want to switch to the high-beams, every thing goes dark. Relay? If yes, where can i find the relay? Thanks Loyale 92 wagon try cleaning the contactors in the high-low beam switch, my fathers mazda truck does the same thing every so often, a few minutes work with a bit of fine sandpaper and its all business again
January 21, 200620 yr Author try cleaning the contactors in the high-low beam switch, my fathers mazda truck does the same thing every so often, a few minutes work with a bit of fine sandpaper and its all business again Thanks for the tip, Do you know where this switch is on a loyale 1992?
