Bleed brakes, now back to mush
So I bled my brakes acouple weeks ago and they did feel firmer and didn't sink as low but now they are back to where they were before (if not worse). The pedal sinks a couple of inches and only gets firm (which is still pretty mushy) about an inch from firewall, kinda scary! I don't think my reflexes are fast enough to yank on the e-brake if I had to so I really want to get these fixed!!
So I've established that bleeding the brakes doesn't fix the problem and I've checked hill holder which is fine.
Where should I look next? I know master cylinders don't usually go out but is it worth a shot?
I had the EXACT same problem with my legacy... master cylinder and new rubber lines cured it... unfortunately I didn't do them one at a time to see which actually fixed it, but if your rubber lines are checked, cracked, missing an outer layer, here is why I would suggest replacing those first:
those rubber lines are multi-layered, and if the outer layers flake off or whatever, when you step on the brake pedal it can cause the rubber to "balloon" out in the line, and be just like there is more volume in the braking system, causing your pedal to have that mushy feeling....
personally I replaced the rubber lines because they were old, and the master cylinder because I felt that's what the problem was, after bleeding my brakes several times like you did
I would think, that if you're positive you got all the air out of the lines and you have NO leaks in the lines when the brake is pressed (you've checked the fluid level and for spots of fluid on the floor right?) Then i think it has the be the master cylinder, either it's not getting the vacuum it needs or the inner plunger is stuffed.
Ya, no brake fluid on the floor. How much were the new lines operose?
