February 8, 200620 yr Hey all! Trying to find a no-splice trailer wiring adapter for my 2005 Baja. I think I've found the wiring plug here, but I want to make sure. I've also been unable to find one specifically made for the Baja, but I have found ones made for the Legacy/Outback. Will these work? http://www.hiddenhitch.com/Products/DisplayAccessory.asp?AccessoryID=16370 http://www.trailerwiring.com/cgi-bin/view.cgi?part=43855 Thanks for your help!
February 8, 200620 yr If I had to guess, I'd say they probly would. Do either harnesses have pictures of what the connector looks like that you hook up to the tail lights? You could compare that to the connector on your baja.
February 8, 200620 yr Author If I had to guess, I'd say they probly would. Do either harnesses have pictures of what the connector looks like that you hook up to the tail lights? You could compare that to the connector on your baja. This is the best picture I could find and while it looks similar (6 pin) it doesn't look the same. White vs grey, and the latch looks different than the picture I linked too......
February 9, 200620 yr Not sure what to tell you. Have you called the dealer to ask for a wiring diagram? You can d/l wiring diagrams from subaru http://techinfo.subaru.com
