drivers window fell off track
So my drivers window won't go all teh way up strait, the rear is on track but the front isn't. i took the door apart and it seems like there should be a bearing/roller holding the window into the track, any body have an exploded veiw of the window workings, or any ideas on how to fix this problem.
Check the nuts that hold the drive assembly to the inner door panel metal. If they are missing or the hole is gouged out (like mine below), the entire track assembly will be out of alignment.
Is there anyway to fix if the holes are too big?
i remember when i took it apart the nuts were loose, i tightend them down but now im scared/ that the holes are opend up.
You could put a washer on it, but there is not a lot of thread to work with. I just bent mine back so it was flat again and cranked down on it with Loctite.
