Evaporative Emission Control (EVAP) warning
My 99 Legacy Engine Check Light is on. Code says EVAP fault.
Any ideas please as to usual problems here?
First check to make sure all the lines that make up the evap system are connected and intact.
Check that the purge solenoid is connected and check it's resistance.
That's all I can think of.
Garage says I need a new vent solenoid - is this the purge control solenoid please?
Gil
Most likely.
As far as I know, there's only one solenoid - it's purpose to vent/purge the evap canister when the ECU tells it to.
Easy as heck to replace.
Thanks for your advice I will look around today for a solenoid
Gil
