February 22, 200620 yr Hello. I am owner of a LEGACY 1.6 GL.I have some questions... Does a 2.0L LEGACY engine fit on my car? Its about time to change my suspension. What kind of suspension do you suggest? I also want change the INTAKE. Does anyone has any suggestion? Will an EJ22 engine fit in my car? Now it has an EJ16. Thanks
February 23, 200620 yr For the most part, all the engines are physically swapable. The wiring is probably going to be different, and that's where you run into issues of having to wire up the proper sensors. We never got the 1.6l in the states. Is it carburated or fuel injected?
February 23, 200620 yr A 2.2 should fit with no problem, as that was the standard engine in the United States. Without knowing the configuration of the 1.6, it's difficult to say if you'll have to do any rewiring.
