i have a 93 legacy 2.2 non-turbo, i need to know if it is a biander or not.
i was going about 70 and my timing belt went out, i pray that nothing else went wrong! i need to know if my valves are bent or not. if you know any thing it would be nice if you would let me in on how my car might be.
thanx
trav.
No idea what you mean by biander but it is a non interference engine and should run with another belt. Make sure the water pump and tensioners are ok because one of them may have failed taking out the belt. If you have the time and money the front seals would be good to do while it's apart.
