October 17, 200322 yr i changed out all my bulbs last night, with the correct ones.. now the stinkin brake light warning light on the dash comes on when i step on the brake or turn on the lights.. any ideas?? i know they work cause i checked them twice...
October 17, 200322 yr The circuit will light the dash warning light if ONE bulb is broken and the brake pedal is depressed. If both bulbs go, then the light will not come on. You may already know this, but it could help anyway... It sounds like there may be a current leak, from one of the bulb fittings. Either a wire is pinched or there is moisture in the lamp unit.
October 17, 200322 yr Author ok fixed this problem, one light was shuttin off when the brake pedal was pushed.. all i did was pull the bulb and turn it around and put it back in, seemed to have fixed it :brolleye:
