88' DL saggin in the rear bad..
well the DL got a new motor, clutch, brakes, and suspension all the way around..
i thought by replacing the worn out struts it would level the rear out.. well now its sits like 2" higher in the front and the back is still sittin on the bump stops practically..
so this tells me the rear coils are shot.. (2wd wagon too btw)
now to the question..
how much longer are the 4wd rear coils vs the 2wd's? and will they fit on my 2wd wagon if i just swap out the hole assembly?
