5-speed swap questions..
just a couple..
say i found a na 3.9 ratio 5-speed for my turbo legacy..
will the na clutch hold up0 to the turbo engine? or can i use a turbo clutch and pressure plate with the na trans and flywheel? i was thinkin the splines might be different.. but i am used to working on the old ea series cars.. this is my first ej car besides the outback..
also are my turbo cv's gonne go on the na 5-speeds output shafts or are the spline counts different there too?
You'll be good with the clutch/pressureplate/NA tranny handling the power, someone up here took an EJ22 five-speed and mated it to an SVX with no problems. Not sure on the spline count though. Jesse (Subafreak) might know.
