Tranny noise
Hey everybody 87 4wd DL wagon push button 4wd got a real weird noise coming from tranny loud humming or vibration as speed increases does not matter if it's in 4wd or no. Any Ideas? :confused:
Hmmm, sounds like my problem... (88 push button 4wd DL Wagon)
Started two days ago, louder when I step on the clutch, sounds a little different in any gear, changes with speed of the vehicle, not the engine.
I was guessing the fluid may be low, but the guy at the oil change place says he can't check it because it's a complicated process involving the speedometer and they aren't set up like a shop. He said he does see signs of a slight leak.
Chilton's says just check the dipstick to the left of the engine oil dipstick. I don't see this second dipstick. Can the guy from the oil change place be right?
How can I check/add manual transmission fluid?
-Leo!
-Leo!
If your spare tire is located in engine compartiment, so under her is second dipstick.
Good luck.
