how much room is there?
A friend of mine is thinking about doing a Subaru conversion in his 86 Vanagon Westy, and I'm just curious how much room there is in the engine bay with an EJ22 or an EJ25 in there. Can you change the timing belts, water pump, rocker cover gaskets, etc without too much trouble?
Anybody got pics that illustrate this?
There's slightly more room with the Subie engine in there than with the VW engine.
Chaning the timing belt will depend on which engine mount system you use... with the KEP mount, it will be tight but doable; with the Small Car mount, you will probably have to drop the engine to get at the timing belt.
Am I correct in assuming that both of you are running the EJ22?
Anybody got an EJ25 in their VW?
