STI Pinks in my '04 TS
I'm looking for a set of STI pink springs for my '04 TS wagon. They say they will only fit '02-'03 but what's the difference? Is it just the top hats? If so can't I just swap the top hats? Or just use the STI struts?
Thanks in advance
-Chris
subaru makes a specific STi Pink for your 2004 model TS
see:https://www.subarugenuineparts.com/advanced_search_result.php?keywords=pink+spring&osCsid=0df280aa9f37a7fe0fa3269e7a198af2
spring rates: 223 front and 195 rear
very streetable. lowers the car about 1"
can be used with OEM struts
not bouncy, good control!
Jamie Thomas
Jamie at chaplins.com
http://www.subiegal.com
Thanks Jamie. One more question though. Is that 1" after they settle or 1" initial drop? This car is my daily driver so I don't want to lower it a full inch. Is there any other options out there? Just trying to close the wheel gap a bit and get a stiffer ride. I'm going to do sway bars and end links first, but I will need springs eventually.
MAYBE 1" after settle
these arent lowering springs per se
they are designed with PERFORMANCE in mind.
less body roll = more control
lower center of gravity = better balance
for the Wagon?
this is the only Wagon specific option
which utilized OEM struts.
the only other option? Japan spec, and you'll need new struts for those.
(super super stiff)
Jamie Thomas
