April 27, 200619 yr well im still working out some bugs on my ea82t (hot wire maf/spyder) (most of them haven beaten:)) the only issue i have left is some stumbling below 3000 rpm its noticiably when im pulling away from a light (it doesnt buck hard like it wants to die) or if i shiift into 2nd way to early and step on it. another wierd thing i noticed is that if im cruising along and step on it it will go good and then give me some backfire around 8psi then go away as it climbs to 12psi. im not really sure what to make of this i was thinking there could be a vacuum leak i read 15lb/hg of vacuum at idle. i cleaned the maf last night, the coil is only a few months old?? anyone have any ideas on this one. Thanks Ty
