April 29, 200619 yr hi subaru XT stick = shift knob, will it fit on subaru loyal automatic ? does anyone can give me a fhoto of shift knob of XT? thank you all.
April 29, 200619 yr The XT automatic shifter will fit a Loyale, but you have to switch the whole assembly, including the part with the gear markings. If you try to just stick the shift handle on, it will be way too tall. It's not too hard to do, I did it in my 92 Loyale when it was still automatic. Make sure the assembly you get has matching markings to your car- they are marked PRND21 or PRND32. Besides the numbers being off, there is substantial mechanical difference!
April 30, 200619 yr Author The XT automatic shifter will fit a Loyale, but you have to switch the whole assembly, including the part with the gear markings. If you try to just stick the shift handle on, it will be way too tall. It's not too hard to do, I did it in my 92 Loyale when it was still automatic. Make sure the assembly you get has matching markings to your car- they are marked PRND21 or PRND32. Besides the numbers being off, there is substantial mechanical difference! hi thank you for the info. moshe.
