replace tone wheel without pulling out front hub?
I need to replace the front ABS tone wheel (or tone ring). Do I have to remove the front hub first in order to install the new tone wheel?
Funny that, I was under my Sube a few hours ago clamping down the heatshields and had a good look at the ABS sensor and tone wheel.
I'd say yes, by the way. The tone wheel is behind the hub.
on what?
On a 1998 Subaru Forester L. Is it possible to wiggle in the tone wheel behind the front hub; the wheel of the tone wheel seems slight larger than the hub (tone wheel is also called tone ring or toothed ring or Speed Sensor ring)?
