If it's an L model with Rear drum brakes, I would ensure the self adjuster are working correctly.
If it is an S model with rear disks, they use a seperate small brake shoe in the center for the emergency brake. If all the above are working properly then the attached .pdf file shows how to adjust the lever/cable.
  • 6 months later...
