June 19, 200619 yr Im trying to get my oil pump off I got it of But I cant clear the main pully.. How do the pulley Off. Clockwise or counter. And I cant get my flywheel to stop moving when I wrech on it.. its i:banana: n 4 wheel drive and reverse but it wont lock it up.. ANY SUGGESTIONS.. NOW i have two broken punches floating around inside my tranny and a brocken screwdriver!
June 19, 200619 yr Put a wrench on the main crank bolt with a breaker bar on it set it against the fender (with Padding) and hit the starter. That should loosen the bolt and allow you to get the main pulley off. Good Luck
June 19, 200619 yr you can also remove a spark plug, then thread as much rope (non-fibrous) into the cylinder as will go. Then slowly crank the engine over by hand until it stops, then you can loosen/tighten the crank pulley bolt.
June 20, 200619 yr Author THANKS FOR THE HELP I ACTUALLY USED A SCREWDRIVER AND LOCKED ON TO THE FLYWHELL AND GOT THE PULLY OFF THANKS FOR THE THOUGHTS I WANT TO TRY THE ROPE ONE TO THATS A GOOD IDEA:cool:
