October 31, 200322 yr Hey, First clutch in my '99 OBS replaced at 38K (ridiculous - only got SubNA to pay for 1/3). Second catching higher at 49K and I don't have any service manuals (does any source sell a reasonably $$$ set?). Any sources for a HowTo? Joe
October 31, 200322 yr you can get service manuals at http://techinfo.subaru.com , or buy a haynes/chiltons at pep boys, etc. i believe that the obs is the same as the leg outback where it has a hydraulic clutch, where there is no adjustment. you probably have air in the system, or a leak. i would try bleeding the system, then check for leaks if the symptoms return.
November 1, 200322 yr Author The Impreza-based OBS has a cable clutch. Dealer adjusted the original when I took it in to complain about slippage. Prefer to do it myself, if possible.
