floater Posted June 26, 2006 Share Posted June 26, 2006 I need the sensor before the catalytic convertor. It looks like there are two options; a universal one that looks like you have to strip the wires and put the connector together and the OE one with the connector ready. The price is $55 for the first one and $85 for the second. Is the cheaper one okay? 96 Outback Quote Link to comment Share on other sites More sharing options...
SuperSubaru Posted June 26, 2006 Share Posted June 26, 2006 The sensor body - business end - is identical (assuming the same manufacturer). If you have a soldering kit, or weather-proof connectors, the universal would do exactly the same job as the OE style. 3-wire = 2 heater, 1 output signal, the sensor metal shell does the grounding 4-wire = 2 heater, 1 signal, 1 ground Save the money. Quote Link to comment Share on other sites More sharing options...
floater Posted June 26, 2006 Author Share Posted June 26, 2006 thanks Quote Link to comment Share on other sites More sharing options...
