July 18, 200619 yr I just had one of my fog lights replaced at my mechanic's -- $$$$! When I went to check on the lights, the other light is now out! Does anyone know if I have to replace the entire bulb or can I just replace the smaller filament thing? (Obviously I'm not a car repair person!) Thanks in advance!
July 19, 200619 yr If the fog light housing is not cracked or broken, you can replace just the bulb. Go to the index of your manual and look up "bulb chart." For my 99 Forester, it's bulb #9006. You should also be able to find instructions for doing it by looking up "fog light bulb replacement," again, in the index of your owner's manual. If you plan on doing it yourself, a screwdriver and some elbow grease is all that you should need. Avoid touching the bulb itself during the installation.
