September 8, 200619 yr As long as the sealing surface is in good shape, that should hold air. I've seen ones with much larger dings hold air. -=Russ=-
September 8, 200619 yr yeah it should... one of my wheels has a worse dent from when I popped a tire on a big rock earlier this summer... not only holds air but it ballanced just fine
September 8, 200619 yr dent seems OK... but a pic of the sealing surface would be needed.. if its not pristine (or close) then there may be issues but if its nice and shiny... should be OK. let us know when you find out :- )
September 8, 200619 yr yeah, that should hold air no problem. you could even have bead sealer put on just to make sure.
