September 9, 200619 yr Axle / Rearend bearing??? Well what I thought was a bad wheel bearing isn't. Only got thing part way apart and I can hear the metal rubbing noise coming from the axle where it bolts to the rear end. Rear axle lub was nice and clean, though I replaced it anyways. Is the bearing sealed on that end? DOesn't sound like a CV, but a grinding bearing that need lub.
September 12, 200619 yr You talking about the bearings in the rear diff, or the bearings in the axle hub. Here's pics of the rear diff & bearings in it. http://www.main.experiencetherave.com:8080/subaru/images/reardiff/
