subie94 Posted September 21, 2006 Share Posted September 21, 2006 anyone ever have their ignition switch become loose inside the column.? this has happened to my 94 legacy and after taking the two plastic pieces off the column,it looked to me that a special tool was required to tighten it..does anyone know if this is true or am i looking at it all wrong?(maybe i need to look again) btw-it does wiggle to bad but it's noticable. any ideas or suggestions? Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 22, 2006 Share Posted September 22, 2006 Is the whole lock loose around the column, like you could spin it around the same way the steering wheel does, or just the electric switch itself. THe switch is held in with a small phillips screw, the lock is held on by two shear bolts. The shear bolts have heads that snap off intentionally when they're installed so that they are hard to take out. You can use a centerpunch or chisel to walk them out and put regular bolts in, or you can ignore it untill it falls off. I'd ignore it, but... Link to comment Share on other sites More sharing options...
subie94 Posted September 22, 2006 Author Share Posted September 22, 2006 i believe it's just the electric switch..gonna have to recheck Link to comment Share on other sites More sharing options...
